Allis Chalmers
Nick R
08-27-2000 13:49:12
I just bought an Allis Chalmers WD, and I don't know anything about it. I would like some information on it like how many were made and how hard it is to get parts for. I would also like to know what are the differences between a WD and a WD 45.
Aaron
08-27-2000 19:23:48
 Re: Allis Chalmers in reply to Nick R, 08-27-2000 13:49:12
The WD had a 201 cubic inch engine, the 45 had 226 (4 vs 4.5" stroke, same 4" bore). The 45 had a taller head, distributer ignition, helical cut tranny gears, bigger carb, 3 disc hand clutch vs the WD's 2. The WD had a plate on the right side of the engine, the 45 did not. A few other differences, curved (45) vs straight (WD) shifter. Parts for both are easily found at yourlocal AGCO dealer or salvage yards.
Aaron
Brian G.
08-28-2000 05:11:53
 Re: Re: Allis Chalmers in reply to Aaron, 08-27-2000 19:23:48
Aaron, True, the "45" has the "tall" head, helical cut gear tranny and the distributer ignition. However, these features were "phased-in" on the WD's prior to the introduction of the WD-45. The "tall" head was introduced on the WD quite early (probably 1950) with Engine Serial #WD289000. The helical cut gear (curved shifter) tranny was introduced on the WD with Serial #127007 and the distributer ignition first appeared on the WD with tractor ser. #136318.
Brian G.
08-27-2000 15:02:46
Scroll down to my response to James Rekus on 8/25/00. The WD Ser. #'s began with #7 1n 1948 and ended with 146606 in mid '53. The WD-45 Ser. #'s began in mid '53 with 146607 and ended in '57 with 236958.
