WD hydraulics
thdrduck
Gave my kid my WD last spring. He is trying to move bales with it and the hydraulics seem really weak. Seems to me that I put universal tractor fluid in the hydraulic system years back, never needed to lift much so didn't notice a problem. Could that be causing the issue or is the pump going bad?
Ideally, when you throw the hydraulic lever up, the lift arms come to the top and the pump builds at least 3,000 psi on your gauge. 3,400 is specs, but 3,000 will work.
Thanks guys, ordered a gauge and will check it out. If it won't pick anything heavy up, I'm sure I will find it's low.
