D19 Gas Engine
I have a D19 gas that got water in the engine and the crank and pistons are very rusty. Is there a Gleaner combine with the same engine that might work for a swap?
My brother got things cleaned up and he thinks all he needs is one piston and sleeve standard bore. I will start calling AC parts guys on Monday.
Nope. The early "G" combine had a G-2800/ 301 gas engine the same as a 190XT. The later model G's had a Chevy 350 industrial/truck engine.
I work for a guy who has an old F gleaner. I am pretty sure it has the 262 motor. I have not posted on Yamagata for years. Hope this works. I live in north central mo.
Hi Galen,
Have you ever dealt with Steve Fischer from Sleepy Eye for AC parts? Great guy to deal with. I don't have a phone number handy now. Good luck. Kow Farmer Kurt
Thanks everyone for all the help. I have Streve's his card and may call him. My brother has a couple other leads. He found a guy who has a parts C2 engine or a new overhaul kit. The guy just used one piston from the combine for a D19 he had. My nephew will measure the pistons and sleeves to compare them between the tractor and the combine engine. My local parts guy says the blocks are the same but he doesn't think the pistons are because the combine has smaller pistons. If he uses used parts he has to find new rings or use the old ones. My brother has to decide if the extra cost is worth it for new parts when the tractor will probably never be used for farming. We also don't know the condition of the rest of the tractor because we bought it not running.
A D-19 engine and a C-C2-older F combine are the same engine. The A and A2 combine have smaller pistons.
If you run out of leads I have 3 or 4 of those blocks over in a building,have to look what they have in them haven't looked in a couple years.Also have a mostly complete
motor out of a gas D19.
