Company Logo Shop Now
D19 Gas Engine
Galen Houk
01-10-2020 20:16:32
I have a D19 gas that got water in the engine and the crank and pistons are very rusty. Is there a Gleaner combine with the same engine that might work for a swap?
Traditional Farmer
01-14-2020 06:27:48
 Re: D19 Gas Engine in reply to Galen Houk, 01-10-2020 20:16:32
If you run out of leads I have 3 or 4 of those blocks over in a building,have to look what they have in them haven't looked in a couple years.Also have a mostly complete
motor out of a gas D19.
Galen Houk
01-17-2020 11:46:57
 Re: D19 Gas Engine in reply to Traditional Farmer, 01-14-2020 06:27:48
Thanks. I think we have what we need but will keep you in mind.
DrAllis
01-13-2020 21:18:29
A D-19 engine and a C-C2-older F combine are the same engine. The A and A2 combine have smaller pistons.
Kow Farmer
01-13-2020 10:11:20
Hi Galen,
Have you ever dealt with Steve Fischer from Sleepy Eye for AC parts? Great guy to deal with. I don't have a phone number handy now. Good luck. Kow Farmer Kurt
Galen Houk
01-13-2020 12:08:30
 Re: D19 Gas Engine in reply to Kow Farmer, 01-13-2020 10:11:20
Thanks everyone for all the help. I have Streve's his card and may call him. My brother has a couple other leads. He found a guy who has a parts C2 engine or a new overhaul kit. The guy just used one piston from the combine for a D19 he had. My nephew will measure the pistons and sleeves to compare them between the tractor and the combine engine. My local parts guy says the blocks are the same but he doesn't think the pistons are because the combine has smaller pistons. If he uses used parts he has to find new rings or use the old ones. My brother has to decide if the extra cost is worth it for new parts when the tractor will probably never be used for farming. We also don't know the condition of the rest of the tractor because we bought it not running.
Tramway Guy
01-14-2020 06:59:54
 Re: D19 Gas Engine in reply to Galen Houk, 01-13-2020 12:08:30
The C2 used the G262 engine as did the D19. The combine governor was different.
B.Jones
01-12-2020 10:03:30
I work for a guy who has an old F gleaner. I am pretty sure it has the 262 motor. I have not posted on Yamagata for years. Hope this works. I live in north central mo.
Walt in Jaxn Tn.
01-13-2020 20:47:51
 Re: D19 Gas Engine in reply to B.Jones, 01-12-2020 10:03:30
I used to live in Bevier.
Galen Houk
01-13-2020 07:36:50
Thanks for the information. We will look for parts first and if we can't find anything, I can get back to you.
DrAllis
01-11-2020 20:09:41
Nope. The early "G" combine had a G-2800/ 301 gas engine the same as a 190XT. The later model G's had a Chevy 350 industrial/truck engine.
DrAllis
01-10-2020 20:27:59
Models C or C2 or early model F combines. You will have to use your governor and carburetor.
Roger Tomfohrde
01-11-2020 15:02:26
 Re: D19 Gas Engine in reply to DrAllis, 01-10-2020 20:27:59
Is the motor from a G the same, I thought it was.
Galen Houk
01-11-2020 14:13:02
My brother got things cleaned up and he thinks all he needs is one piston and sleeve standard bore. I will start calling AC parts guys on Monday.
Today's Featured Article - Major Problems - by Anthony West. Following the aquisition of the two Fordsons to my collection I found that I was struggling to move them about. I had considered the possibility of driving the "F" to and from shows but anything other than local rallies was totaly impractical due to its sedate pace. I had also considered buying a landrover and trailer, but the price of a ... [Read Article]
Latest Ad: 3 point drag arm for 420 HD crawler right side [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
