Company Logo (800) 853-2651 Shop Now
Re: CA final drive clutch question
T Seifert
08-26-2000 10:56:36
The CA clutch servs the same purpose as the WD hand clutch. The AWD hand clutch is a wet clutch (runs in oil) whereas the CA clutch is dry , so therefore it won't take the abuse that the WD clutch will. It is said that with the CA clutch that you loose about 20% of your maximum pulling capacity.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c ... [Read Article]
Latest Ad: 4386 or 4586 IH [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
