Company Logo (800) 853-2651 Shop Now
AC5040 stuck in gear
scratch67
12-03-2019 14:04:08
Took cover off. None of the shifters move. I suppose the shifer fork is misplaced? How do I fix this?
Why does this happen?
Thanks
Mark
scratch67
12-04-2019 12:39:13
 Re: AC5040 stuck in gear in reply to scratch67, 12-03-2019 14:04:08
Got it fixed. Used large screwdriver to jostle whatchamacallit below the low gears 1-4 shifter bar. It popped back in place, all lined up.
I did think about jacking up left wheel, next step if needed.
Thanks to all for the advice.
Jim.ME
12-04-2019 07:30:05
Are the rail slots in line? It may take a bit of force to free it if you got it locked in two gears. Jack it up so one rear wheel is off the ground, That may help relieve some of the stress.
scratch67
12-04-2019 06:10:15
I did the screwdriver thing yesterday, none of the rails would move. Will try it again this morning.
dzc3
12-04-2019 05:26:00
Jim.ME has a good point this was what happened with my 5040. Simple fix, if that's what is wrong. Line them up with a screwdriver replace cover and you will be good to go
scratch67
12-03-2019 18:26:46
More info
Motor was running when it got stuck.
After shutting down, wouldn t turn over.
Rails would not move with clutch in or out.
With clutch in I could spin the gears.
scratch67
12-03-2019 18:19:55
I just started up moving shift stick from neutral to 3rd. Not sure about transmission type. I have 1 2 3 R low and 4 5 6 R high, single shift stick.
Jim.ME
12-03-2019 15:41:22
It is likely something is out of place. What transmission does it have, 6/9 or 8/12? Is it locked in one gear (it will move) or locked in two gears (stalls if you let the clutch out)? Were you shifting it when it occurred? What gear was it in and what gear were you going to? When the gears are in neutral the notches in the shifter rails where the gear shift lever go should be centered and all in line, are they?
If you don't have the manuals now might be a good time to get the service and operator's manuals.
http://www.agcopubs.com/default.aspx?model=5040&brand=44127&keywords=&searchForm=0
The parts book is available on line at https://apb.agcocorp.com/login.aspx?region=NorthAmerica. Click on "View Books" in the Guest User area and search 5040 on the next page to see the parts book.
Today's Featured Article - Search For Spares - by Anthony West (UK). Following on from the aquisition of the old Fordson F, I was very much in need of spares. As a novice though I didn't appreciate the fact that there were so many Fordson tractors made, that all the other makes seem rare by comparison. As far as I was aware a fordson was a fordson and it was only through trial an ... [Read Article]
Latest Ad: 48 John Deere GW in pieces [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
