Pulled my D17 Diesel yesterday. 4500lbs 6
mph and 8 mph. Motor running good. Pulled
in 2nd hi. 18.4X38 cut tires. Chart says 9
mph at 3000. Problem was tires stopped
turning at end then started again. Still
got 4th in 6 mph. Probably over 15
tractors. USAP at Princeton In. How can I
tell which is slipping. Or will the two
speed never take 250 hp. When I drove out
the door and pushed the clutch in. The
tractor stopped. Like brakes were on. I
moved hand clutch to neutral then to low
then to hi. And problem went away. Thanks
for any help.
for any help.
