allis chalmers I-60/D15 reverser
kenshinzx
New User
the forward reverser on my early 60's I-60 doesnt want to stay in forward most of the time, reverse works fine but i have to hold it in forward most of the time, any thoughts on whats causing this?
Things are getting worn. There is a stop bolt that the lever rests against when clear forward. Remove some or all of the washers under the head of the bolt or maybe remove the bolt and see what happens. Also make sure the setscrew at the base of the lever is TIGHT by loosening the jam nut first and tightening the bolt. CHECK THIS FIRST !!!
