Allis b starter
Scooter90
New User
I have a 1941 Allis b with a magneto and already converted to 12 v system. ( the ground is negative) It has a kill switch and a starter rod. Can I change that to a key switch only or a switch and starter button and how would I wire it. An image or photo would really help.
This is a good article that Rodney K. Thompson, AKA Rod (NH) has written up and put on his web site.
http://www.rodnh.byethost12.com/acb/solenoid starter/solenoid start.htm HTH Elliott
The NAPA Kit referred to is Echlin # SF139. Need a big heavy duty soldering iron or torch to heat up a large bolt to do the soldering of the threaded post. Some people have suggested drill and tap, but I think that might be a little on the weak side.
I am no electrical expert but I can say this, my B that I inherited from my father was switched over to a key switch. So I know
it can be done.
Ah but does it have a mag or a distributor?? One with a distributor it is easy to do the key switch but a mag since it is a stand alone system doing a key switch to spin it over and also shut it down is hard if it can even be done
(quoted from post at 12:14:43 11/21/19) Ah but does it have a mag or a distributor?? One with a distributor it is easy to do the key switch but a mag since it is a stand alone system doing a key switch to spin it over and also shut it down is hard if it can even be done
I've converted quite a few old tractors to a solenoid and key switch starting system.
A garden tractor or small engine key switch of the type the shorts out the magneto to shut down the engine does the job on a mag-equipped full-sized tractor, as well.
Bob your right but would the common man know how to wire one of those up?? Up till you posted this I had never thought about a lawn mower ignition type switch.
(quoted from post at 06:49:07 11/23/19)
Type or copy paste into your web browser url
www.rodnh.byethost12.com/acb/solenoid%20starter/solenoid%20start.htm
I ended up going to Rodnh.byethost12.com. Plus I was able to see one on another similar tractor so I think I have it now. Thanks!
Very cool info. I don't know when/if I may use it, but still good to learn more stuff. I suppose that idea would work on other starter applications. Thanks Rod for sharing.
(quoted from post at 09:38:43 11/23/19)
The link still works for me, I'm using Win10 with explorer11 browser. You still got to the article and that's what matters. Looks like its gonna help others to. Rod has more article that are very helpful also.
