My tractor was apparently one of the first wd 45 or last of wd and has a wd engine with a wd45 bent transmission shift lever and I believe the rest of the tractor is wd 45. The story I got is that they had some wd engines left over when they started up the wd 45 tractor line! Does that sound right to you guys?
Would my fuel shutoff valve be the same on both wd and wd45 tractors and if not which do I have? I found several sources for parts on ebay but they all refer to the wd45 and do not appear the have the brass fitting, just a female pipe thread. In short I wish to keep my steel fuel line with its fittings and do not know if those valves on ebay are exact replacements! Is the brass fitting on the valve removable?
