WD 45 Fuel Shutoff
WayneMo
Where can you buy a gasket and filter screen for a WD 45 fuel shutoff? I would like to replace these and keep the original metal fuel line from the shutoff to the carb with its fittings.
What do you guys do when the shutoff fails? Replace the fuel line with in line filter and shutoff valve from a lawnmower using copper tubing?
Orscheln's has the screen and gasket. Or you can get the gasket for the bowl at O'Reilly's [[art number 398 fuel strainer gasket. As for the fuel shut off take the Part to O'Reilly's and they should be able to match it up to something
If the shut off valve fails replace it with the correct shut off. TSC normaly has them on the shelf. Do a google search for WD fuel shutoff you'll find there really available from many online sellers it's a coman part to allis IH ford and many others. Reuse your existing line and fittings.
