Buddy Terry
I'm in need of some expert advice on my C narrow front end, was wobbling so bad that you looked like you had been at the bar. On a more serious note, Had almost a full round of free play in steering wheel, adjust steering gear box, no results, found steering arm on bolster had lots of free play, remove lower bolster checked pinion and segment gear, did not see anything, had another steering arm and segment from another C parts tractor, installed them and reinstalled bolster, steering so tight that it was hard too steer, even with front end off ground, reinstalled tires and lowered, now that load is on it, cannot turn wheels backed off nut on shaft but still no response. So how tight should the nut be on segment gear, according to manual as tight as you can get it, so would the segment gear and shaft cause problem, they are splined versus tapered that was removed. Sorry for long post. Any suggestions will be greatly appreciated. Thanks
