Quintin_D
New User
So, I just picked up an AC WD 45. It has a gas engine. I was wanting to put a turbo on it. I want it to have some low end power but I want it to make a good power in mid and high range rpm. What size turbo/exhaust housings should I go for, and what can I do to better prepare the tractor for the turbo set up?
Guys on the N board used to talk about supercharging their little Ns by using a GM 454 smog pump driven by the fan belt and then by
using an NAA carburetor to get the mouth pointed forward they'd do a rather simple hose connection and be good to go. Said it
helped a lot.
