Company Logo (800) 853-2651 Shop Now
D17 gas diesel
johndeerered
10-09-2019 21:25:21
Can you put a gas head gasket on diesel 262 d17 to increase compression for better starting. I think there is about .30 thinner on gas gasket would that help any at all with just .30 thousands different, thAnks for any info.
Alvin 41
10-10-2019 18:47:08
 Re: D17 gas diesel in reply to johndeerered, 10-09-2019 21:25:21
Did the reverse years ago on a Ford 5000D. Had dealer overhaul and it didn't start as well as before. Thinner original gasket was no longer used.
Aaron SEIA
10-10-2019 12:39:45
Maybe he means to use the gas 262 head gasket from a D19.
AaronSEIA
johndeerered
10-10-2019 21:13:19
 Re: D17 gas diesel in reply to Aaron SEIA, 10-10-2019 12:39:45
That is correct 262 gas head gasket on 262 diesel for a little more compression.
leroy in ne
10-10-2019 12:29:32
To the best of my knowledge the D 17 gas is 4 cylinder and D 17 diesel is 6 cylinder however I believe the D 19 is a 262 cubic inch gas burner as well as some Gleaner combine engines.
Brian Jasper co. Ia
10-10-2019 08:46:38
You will want to pay close attention to piston protrusion. The factory specs is .029 on the high side. A used diesel head gasket is in the .045 range. If your block has been surfaced multiple times to fix sleeve recession, you could end up with pistons hitting the head. Measure measure measure, then measure again.
Traditional Farmer
10-10-2019 06:15:19
Might want to contact Lubbock Gasket they will make you a custom gasket for about any application after you explain what you need.Had them make me a head gasket for a Cockshutt 50
pulling tractor years ago worked good.The 50 engine is basically the same motor as the D17D BTW.
DrAllis
10-10-2019 06:10:44
It couldn't hurt. I'd think valve to piston clearances would still be OK. How long the gasket will last is the question. You are on your own.
johndeerered
10-10-2019 06:47:09
 Re: D17 gas diesel in reply to DrAllis, 10-10-2019 06:10:44
Thanks for the replies I think I will give it a try never know I guess till you try
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
Latest Ad: 3 point from farmall M. dual cylinder, like new [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
