Wd45 what haybine to use
WD45cab
New User
I m looking to find out what he buying I can use with my WD 45. I would be using it to cut alfalfa Timothy mix pa I would be using it to cut alfalfa Timothy mix hay. Any help would be much appreciated.
I would think one like the NH460 I have would work. A WD45 is around 45HP and I pull it behind my Lover 77 which is rated at less HP. Yes the NH460 is very old but one that is sickle bar cut it should handle. A disk bine on the other hand not likely
Should be able to cut with most any 9 foot haybine. You might need to slow down a
bit in heavy hay.
Ben
You can pull any seven or nine ft haybine you buy. You will most likely be cutting in low gear or maybe second in lighter hay. First hay I ever cut was with a WD45 and an IH 990 seven ft haybine. Best friend from school always pulled a nine ft Allis haybine with his 45. Tom
