Company Logo Shop Now
D19 PTO..........
Goose
09-09-2019 07:16:41
I posted on another forum the other day that I'd had a mishap that bent the PTO shaft on my D19 Allis. I've made progress on straightening it by putting a hydraulic jack between the drawbar and the tip of the PTO shaft and applying pressure against the tip of the shaft. It's working little by little, but it will never be perfect again. A fellow had a good used shaft on EBay for $75 so I sprung for it.
My question: does anyone know exactly how to change these PTO shafts on a D19? I have a parts diagram that shows the parts clearly, but no instructions for changing.
From the parts diagram, it looks like you could just pull the old shaft out and put the new one in, much like an H or M Farmall. However, I'm not sure about the shift mechanism. My parts diagram shows the shift mechanism, but not where it's located or how it works. I don't want to pull the old shaft out and hear something go "clunk" inside the housing so I have the tear the tractor half apart to find out what happened and correct it.
I can get by this fall without using the PTO on this tractor, but since I'm getting a good used shaft I may as well plan on changing them.
Thanks in advance for any info.
DrAllis
09-10-2019 05:21:58
 Re: D19 PTO.......... in reply to Goose, 09-09-2019 07:16:41
Drain out the oil from the trans/diff and the hydraulic compartment. Remove three bolts and give it a yank. Replace the seal and Oring with new and you're good to go. No problem with PTO shifter coupler.
Goose
09-10-2019 07:06:33
 Re: D19 PTO.......... in reply to DrAllis, 09-10-2019 05:21:58
Thanks!
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: I have A narrow front end from 65 Massey and also a front guard for a 65 Massey call or e-mail for price. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
