Lumbersawyer
- Location
- Grand Rapids, MN
The Allis C I purchased has electric start that is of course 6 volt. I see field coil kits available to convert to 12 volt. Is that all that is needed to switch the starter over to 12 volt?
My tractor does not have the generator or the mounting bracket. I want to intall a single wire 12 volt alterator on it which is a simple wiring harness to build. I rewired my 4010 JD to 12 volt from 24volt with a new starter and alternator. It works very well. Just learning and asking if anybody has done this?
