Company Logo Shop Now
TractorLinks.com
WD45
Mckim90
09-04-2019 18:53:15
is it possible to make a wd45 have close to 70 horsepower with the same block and head if so can someone tell me along with if it is possibly to hookup a turbo to one as well somehow.
DrAllis
09-05-2019 10:26:13
 Re: WD45 in reply to Mckim90, 09-04-2019 18:53:15
It can be worked over/modified to fit your manifold and be made compatible with your governor linkage.
Mckim90
09-05-2019 05:55:58
So a d-19 carb will bolt right on a 45 manifold.
DrAllis
09-05-2019 03:32:34
What are your intended uses of this 45 HP tractor that now has 70 HP ?? Yes, it certainly can be done, if your pocketbook is large enough. A turbocharger will require using very high octane gas all the time and I don't feel is a good idea. Connecting rods are kind of light for a turbo, altho I do know of at least one that has been done like that. Keystone turbos will sell you a "kit", and then when it doesn't work, they don't know who you are. If you are thinking of tractor pulling it, a turbo will see to it you won't get to pull for competition, only exhibition. Raising the compression to 8.0 to 1 (a 170 motor kit) and using a modified D-19 carburetor and D-17 governor spring will get you to the 70 HP mark. A 175 grind on your camshaft will get you a few more HP. All these changes will run on 87 or 89 octane gas.The only thing you can do without tearing down the engine is the D-19 carb that has been made to fit your engine.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
