Logan fees
New User
I have a 1937 Allis Chalmers WC with a zenith carb. I am having issues with the carb flooding out my tractor and not allowing it to start every time. When I try cranking it I can smell alot of fuel coming from exhuast and may have a little fuel run from the carb on occasion. That being said there has been a couple times that I did get the tractor going and after a bit of adjustment it runs fine and will run fine and run for as long as I will let it. But if I shut it off I'm back to flooding. Ive taken the carb apart a few times to check the float and Clean it. I am not a good carburetor guy but everything seems to be fine. I have also pulled all plugs and I do have fire to all cylinders. I'm not sure what I'm missing or doing wrong and some help would be appreciated. Thanks
