Company Logo Shop Now
D17 power steering
dhermesc
08-19-2019 07:27:25
About 90% of the time the power steering on my D17 (Series IV) works perfect - you can spin the wheel with finger - the other 10% of the time the power steering goes away and you are arm stronging it. Any input on the problem? Hydraulic oil reservoir is full.
DrAllis
08-20-2019 05:23:31
 Re: D17 power steering in reply to dhermesc, 08-19-2019 07:27:25
I would assume the power steering (barring leaks) probably has the same oil in it from 1967.[/quote] Exactly !! There is no filter of any kind on the power steering, so it is somewhat important that the oil gets changed once in a decade or so. The Owners manual said every year they wanted the oil changed. if the tractor sits outside in the rain all the time, once a year is still a pretty good suggestion.
DrAllis
08-19-2019 10:51:21
When's the last time the power steering oil was changed ????? Takes 5 quarts of Universal hyd fluid (HyTran--HyGard---whatever) and fill port is behind the grille screen and ahead of the radiator. Fill about 1/2" above the gear inside. Overfull will vomit out the excess. Drain plug underneath and just above the right side tie rod. Takes 1 1/8" wrench. There is a splined steering coupler underneath the generator that should have some WD40 sprayed inside of it and work the steering back and forth to lube the splines. Power steering belt has to be fairly tight or it will slip when cold.
dhermesc
08-19-2019 11:13:36
 Re: D17 power steering in reply to DrAllis, 08-19-2019 10:51:21
Did not know that - I assumed it drew on the tractor reservoir. I will check it out this evening.
I drained the hydraulic system when I bought the tractor - I would assume the power steering (barring leaks) probably has the same oil in it from 1967.
Bob Bancroft
08-19-2019 09:50:50
How's the belt?
Bob Bancroft
08-19-2019 09:58:30
 Re: D17 power steering in reply to Bob Bancroft, 08-19-2019 09:50:50
And I just noticed you said "hyd oil reservoir". Did you mean steering reservoir?
Latest Ad: Heat houser for a john deere 620 [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
