HELP! 7000 Allis 3 stage powershift
AdamCa
New User
I need some help! I have a 1978 7000 3 stage PowerShift. I was baling hay today with it without any issues. I shifted from stage 2 to stage 3 and it quit moving. It won't move now. I have hydraulics on baler tailgate and I have power steering. The hydraulic reservoir is full on the site glasses. Any ideas?
Clutch disc on the flywheel has failed. You say 1978, so I'm guessing a black painted chassis tractor?? with the T-handle gearshift ?? If it is a brown paint chassis with the gearshift on the floor, the PTO should still work.
Foot clutch ate her pigs. Remove the square cover under the bellhousing and there will probably be shrapnel laying there. Split the tractor to fix.
Clutch disc, pressure plate, throw out and pilot brgs, rear engine crankshaft seal and sleeve and clutch shaft seals and gaskets. Also machine flywheel to make it smooth again. I have no idea where you can purchase parts new or reman. I'd say $500 minimum and up to $1,000. Labor is 8 to 10 hs at whatever your prevailing labor rate is.
Thanks! This gives me a good starting point and an idea before I take it in. I appreciate the info very much.
