Company Logo Shop Now
TractorLinks.com
HELP! 7000 Allis 3 stage powershift
AdamCa
07-19-2019 18:01:39
I need some help! I have a 1978 7000 3 stage PowerShift. I was baling hay today with it without any issues. I shifted from stage 2 to stage 3 and it quit moving. It won't move now. I have hydraulics on baler tailgate and I have power steering. The hydraulic reservoir is full on the site glasses. Any ideas?
AdamCa
07-21-2019 04:23:07
 Re: HELP! 7000 Allis 3 stage powershift in reply to AdamCa, 07-19-2019 18:01:39
Thanks! This gives me a good starting point and an idea before I take it in. I appreciate the info very much.
DrAllis
07-21-2019 04:16:35
Clutch disc, pressure plate, throw out and pilot brgs, rear engine crankshaft seal and sleeve and clutch shaft seals and gaskets. Also machine flywheel to make it smooth again. I have no idea where you can purchase parts new or reman. I'd say $500 minimum and up to $1,000. Labor is 8 to 10 hs at whatever your prevailing labor rate is.
AdamCa
07-21-2019 04:09:25
What s the approx cost to fix parts and labor? Just a rough estimate
DrAllis
07-20-2019 19:48:12
Foot clutch ate her pigs. Remove the square cover under the bellhousing and there will probably be shrapnel laying there. Split the tractor to fix.
AdamCa
07-20-2019 05:08:24
[quote="ben brown"](reply to post at 19:24:44 07/19/19) [/quote
It's a maroon belly with the gesrshift in the floor. I have 3 stages on the right side console for each gear. I believe I have pto and all hydraulics. The tractor just won't move.
ben brown
07-19-2019 19:24:44
you may have striped the splines on your toque limiter clutch plates
DrAllis
07-19-2019 19:23:30
Clutch disc on the flywheel has failed. You say 1978, so I'm guessing a black painted chassis tractor?? with the T-handle gearshift ?? If it is a brown paint chassis with the gearshift on the floor, the PTO should still work.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
