Got the CA home
I picked up my 500 dollar CA today. We had to dig out around the barn doors to get them open so we could pull it out. Been sitting for 12 years. The lady said it came with 4 implements so I got a 5 ft king kutter rotary mower, 2 bottom AC llow, 4 ft blade and a 6 ft single gang disc along with the tractor.
One rear tire is new, the other is short so I ordered one to match from Walky World. I pulled the plugs and put in a couple squirts of engine oil, then pulled the starter and turned the flywheel with a bar. Turns easy. Gas tank has no rust, just some old dried out gum so i put in a half gallon of fresh gas and will let drain it in the morning. I popped the distributor cap and the points look new. Fresh gas and a good battery and this thing might go. There are lots of hydraulic leaks from the looks of the crud at the back and the rear rim is going to take some repair work. I think i could sell the mower and blade and get back my 500 so i think I'm in good shape. Looking forward to getting it running. src="https://www.yesterdaystractors.com/cvphotos/cvphoto29358.jpg">
<imsrc="https://www.yesterdaystractors.com/cvphotos/cvphoto29359.jpg">
Very nice, you did well, very easy to put 3 point on it. Read up on the live poer unit those were an issue (axel clutch).
