Company Logo Shop Now
TractorLinks.com
190 allis will not move.
funky_g00
07-07-2019 08:41:42
I have a friend with a 190 allis that they asked me to fix for them. The problem is that the tractor will not go when placed in gear. The most you get out of it is what I would call a hydraulic oil drag, meaning that you get a slow 1-2 inch roll in any gear and that is it. Near as I can tell the main clutch is not slipping and that is has something to do with the hydraulic power director. I have read that the PD can be a problem with these tractors but that is about all I know. I do not have a manual but my friend is supposedly getting one for me, but have not seen it yet. A little back ground on the tractor is that they bought it on the neighbor's estate sale, could not get it to start as the fuel system was all gummed up from old fuel, so they towed it a mile to their place (it may or may not have been in gear when pulled, there is some finger pointing going on). They got it running and there it sits. Until I get my hands on a manual I am at a loss. Any help would be appreciated.
DrAllis
07-10-2019 05:07:09
 Re: 190 allis will not move. in reply to funky_g00, 07-07-2019 08:41:42
300 will work. 500 is better.
DrAllis
07-08-2019 13:55:30
Good luck with the filter change, cause that isn't the problem. Next step is to engage the PTO to see if it runs and if it does, shift the trans and Power Director clutch into gear and see if it STOPS. If it stops, the foot clutch disc must have the center ripped out of it. Next step is to pressure check the power Directors clutch pressure and be sure it has 250 psi or more on both LOW and HIGH sides. Test ports are 1/8" pipe thread right on the valve under the platform. Also, if the linkage going to the pressure valve under the platform is disconnected or broke, you will see that when pressure testing.
funky_g00
07-09-2019 11:42:34
 Re: 190 allis will not move. in reply to DrAllis, 07-08-2019 13:55:30
What size guage do i need? Is a 300 psi sufficient, or will the high side pressure be upwards of 2500 psi that most allis tractors run for hydraulic pressure? The linkage is ok on the valve.
DrAllis
07-08-2019 07:21:30
#1. There has to be power steering or the Power Director clutch can't work. So, is the hydraulic system FULL of oil?? There are TWO dipsticks under the floor at the gearshift connection under the seat. Left is for hydraulics/steering/power director. Right is for the trans/differential. #2. The Power Director lever has to be forward for HIGH or rearward for LOW or the tractor cannot move. Push down on the big knob and push or pull the lever. #3. Towing it was a bad idea.
funky_g00
07-08-2019 11:49:28
 Re: 190 allis will not move. in reply to DrAllis, 07-08-2019 07:21:30
The power steering works good, it has a loader on it and the remote hydraulics for that works good. Both of the reservoirs are over full of oil. The transmission oil sloshes around when tractor is in gear so that tells me the main clutch and transmission are turning/working correctly. I am engaging the power director in high and low and at idle and full throttle and all I can get is that little initial nudge/roll from the tires. I did tell them after the fact that towing it was not a great idea.
Jerry Coulter
07-07-2019 14:38:34
Dad's 190XT did that and the fix was to replace the oil filter beneath the floor board.
funky_g00
07-08-2019 11:50:58
 Re: 190 allis will not move. in reply to Jerry Coulter, 07-07-2019 14:38:34
I will suggest that as the filter does not look like it has been changed in a LOOONG time.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
