My faithful AC 170 failed me yesterday while getting ready to bale hay. While backing in reverse, the tranny made a "thunk" and the tractor stopped moving. I found I could no longer shift into (or out of) any gears. After inspection with the tranny cover removed, I found the forward shift fork (gears 4-6 and 7-8, I believe?) had snapped off and was loose in the tranny. The idler controlled by the shift fork was all the way forward (I'm guessing in gear 7-8?). I hastily tack welded the shift fork to the broken pin as a quick fix and moved all the gears to neutral (I think?). I then re-installed the cover with all three forks in the neutral position. At that point, I could shift gears, but the tractor still won't move, and the engine bogs down when I engage the power director. What's the best way to diagnose this problem, and how can I unlock the tranny if it is indeed stuck in 7-8 and reverse at the same time?
On a side note, I turned to my trusty D17 series II to finish my baling, and got the hay in the barn before it rained, but I'd love to have my 170 back up and running! Thanks in advance.
