Company Logo Shop Now
TractorLinks.com
WD 45 Radiators
GregoryKS
06-11-2019 19:16:19
Did WD 45 original radiators come with the upper outlet tilted to the left (from Drivers seat). I took mine to outlet who has been replacing WD45 rads for years and never saw one like mine. He says it looks like someone welded it that way. My upper hose was perfectly straight. If the upper outlet on replacement radiator is no tilted but straight, do i just try to find a hose that will fit?
4wdtom
06-12-2019 05:23:34
 Re: WD 45 Radiators in reply to GregoryKS, 06-11-2019 19:16:19
The temp gauge should be centered in the opening in the hood and the hose neck should line up with the engine connection. They can be soldered in not in proper alingment, the radiator shop that did mine got it off a bit and the gauge isn't straight. The fitting in the radiator has a strut that goes to the front of the tank and is soldered there as well as the back, makes the whole thing stronger.
Nordic
06-11-2019 20:11:10
That's what happened for me as well. The aftermarket rad had the upper pipe coming out straight and I could no longer use the original hose. I had to try a couple of different flex hoses from NAPA before I got one that works. I'm away from home for a couple of days but if I can get the number off the right flex hose I'll post it here once I'm back home.
GregoryKS
06-12-2019 04:52:04
 Re: WD 45 Radiators in reply to Nordic, 06-11-2019 20:11:10
Great! I"ll look forward to the number. Thank you Nordic.
GregoryKS
06-13-2019 20:06:47
 Re: WD 45 Radiators in reply to GregoryKS, 06-12-2019 04:52:04
Thanks Nordic.I'll go see Napa
Nordic
06-13-2019 18:57:24
I checked the tag on the upper flexible hose on my tractor. Part of the numbers are missing. The Napa number is NBH FF ... , it should have three digits after the FF. By carefully measuring the length it appears to be 10.5 inches and of course the diameter is 1.5 inches. Whatever parts outlet you are dealing with should be able to find the right appliation by the dimensions. I hope this may help somewhat.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
