Allis CA rear "inside" weights
Hi, after days of searching with little to no information I thought I'd post on here.
I am looking for information on the inside wheel weights available for the Allis CA with power spin out wheels.
My OEM manual says up to two weights for the inside, unlimited for the outside. It also says "see machinery catalog." I am unsure if this is a standalone catalog, or one of the implements manuals. It gives no other information.
I'm looking for a part number, casting number, dimensions, pictures of these inside weights.
I saw saw mentioned that the standard B and C weights might fit but can not figure it out, as there are two casting numbers for those AM3138-4 and -5.
Also interested in knowing how to mount/position the bolts when both inside and outside weights are installed.
I know AM3733-2 are the outside ones, I'm interested in the inside ones. Thanks in advance.
I have been around a whole lot of CA tractors (as well as all older AC models) and have never seen inside rear wheels or ever heard of any,of course that doesn't mean they don't exist but they would be really rare.The C and late model B did have inside rear weights for the rear but won't fit a CA rear wheel.The front inside front wheel weights used on the D10 and D12 will fit a CA.
As I remember, the inside weights were the first weights bolted to the wheel and the kit came with shorter bolts. Then you could add another weight onto the first weight and that kit took longer bolts which went through both weights.
With the wheel dish in there isn't much room on the inside of the wheel, the final drive reduction is there. With the wheel dish out, maybe you could get a weight on the
inside.
Thank you everyone for the information.
It seems now, as was stated, the "inner" or inside weights are the first of the stack mounted outside. The wording in the manual fooled me, this makes more sense. The first weight also takes the special cotter pin drilled bolts.
If I was only to mount one weight per side, is it proper to use 2 or 4 bolts per weight? The manual says those cotter pin bolts are "quantity 4" I am thinking thats 2 per side. The diagram seems to show that. I am sure 4 would work but just wondering what was OEM.
I found this on the allischalmers forum. Only reference Ive seen a weight mounted inside. No information on it, I now think its a non-Allis weight or one with the ID bored out to clear the CA hub.
This picture and my now understood misinterpretation of the manual is what set me off on this chase.
Thanks again.
[/img]
