Company Logo (800) 853-2651 Shop Now
Rod Bearings
jwieber
05-20-2019 12:08:18
41' B
installed rod bearings last night and now i cant spin the engine.
is there supposed to be shims between the cap and rod?
standard bearings replaced with standard bearings.
no shims present when i tore it down.
all rods and caps clearly labeled and according to the manual i purchased, #1 & #3 installed with long side of bearing towards flywheel and #2 & #4 towards the timing gear (front).
which made all of the markings on the same side, facing Left.
is it necessary to file the bearings down flush with rod and cap or are the left proud for a squish factor?
thanks
jwieber
05-21-2019 07:03:54
 Re: Rod Bearings in reply to jwieber, 05-20-2019 12:08:18
found an issue with #1 a little emery cloth cleaned right up.
everything is spinning just fine 2,3,&4 are at .002" and #1 is a little tight still just on the very edge. gonna run it.
just hope i can figure out the timing now.
thanks
jwieber
05-21-2019 06:58:09
no time.
jwieber
05-20-2019 15:02:48
Thank you, I picked up some plastigauge today. I thought maybe I could file the bearings. Assuming that's where the excessive pressure is coming from. But I'll check it first.
Dick L
05-20-2019 14:19:19
Now way to make a call without checking clearance. If you are using new bearings on a crankshaft that has not been freshly ground you will most likely need to file the bearings to get the .002 clearance without forcing the bearings in toward the journal.
Here is a link to some pictures on fitting new bearings to a in spec crankshaft slightly under size from ware.
I mic the journal and then mic the inside of the bearing clamped in the caps. I file the bearing end without the tab still in the cap to make sure the bearing end stays square. If I need to file .001 I use feeler gage to measure how much the bearing end is above the cap before filing. I want .004 difference between the journal and the bearing clamped inside the caps That gives me the needed crush.
Dick L
05-20-2019 14:22:03
 Re: Rod Bearings in reply to Dick L, 05-20-2019 14:19:19
Micking the difference this way will tell you if you need shims. With no shims now you may not need them but then again you might.
jwieber
05-20-2019 14:17:50
[quote="Aaron SEIA"](quoted from post at 12:52:53 05/20/19) Should be shimmed with a final clearance of .002"
AaronSEIA[/quote]
Where can I find said shims?
Aaron SEIA
05-20-2019 12:52:53
AaronSEIA
kl in wi
05-20-2019 12:42:46
Mine has shims in it
teddy52food
05-20-2019 19:06:40
 Re: Rod Bearings in reply to kl in wi, 05-20-2019 12:42:46
Get the rods resized & forget about the shims.
Today's Featured Article - The History of Old Abe - by Staff. The Case Eagle - Old Abe - is a well known industrial trade-mark throughout the main streets and countryside's of thousands of cities and hamlets in the United States and civilized countries the world over. King of the air, the eagle is an established symbol in American life and heritage. The Case Eagle Old Abe is far more than merely a trademark. He is a character out of history, a bird with a personality and a story all his own. The story begins in the early spring of 1861. In the wild nor ... [Read Article]
Latest Ad: WANTED Rumely Oil Pull Models W X or M [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
