Re: B-IB-C engines?
Dick L
08-14-2000 22:07:21
The numbers you are referring to are casting numbers. The numbers you want to find are located on the block flange where the pipe comes out of the oil pump or by the air cleaner. (stamped in) If you have a C operating instruction manual look on page 31 lower right picture. (engine serial number) I am looking for inforation on the different parts used such as the cast iron valve covers, cast iron pan, and cast iron bull gear covers. When and why! My 1945 C has all three and I found another C with all three but the serial number had been removed.
huck
08-15-2000 06:13:17
 Re: Re: B-IB-C engines? in reply to Dick L, 08-14-2000 22:07:21
AM stands for allis milwaukee it is a casting # not the engine # the engine # is located on a boss on the bolting flange of engine just below & behind air cleaner.i own a B high crop that has a CA engine it is late production 1955.i think allis used whatever engines available at the time of manufacture whether it was b,c, or ce engine hope this helps. huck
