Company Logo Shop Now
TractorLinks.com
Changing the front tires
Redhawk
05-09-2019 16:47:40
I have a problem that I would like to post. My Allis Chalmers C has a couple of bad front tires that I need to replace. The problem is that I currently donít have the ability to crank it with the starter. I have been rolling it to kick start it. In addition, it has a Woods L306AC belly more mounted on it so I canít jack it up under the torque tube. Any suggestions for how to get it jacked up and change the front tires?
steve_in_mo
05-09-2019 18:21:12
 Re: Changing the front tires in reply to Redhawk, 05-09-2019 16:47:40
Those little tractors aren't very heavy. A bottle jack under the end of the axle would do it.
A 4 x 4 and some cribbing would do it.
Dick L
05-10-2019 04:58:10
 Re: Changing the front tires in reply to steve_in_mo, 05-09-2019 18:21:12
I have jacked the C's using a 2"X 4" under the pan from the time I had the first C years ago. As stated they are not all that heavy. I never used a jack without a board to distribute the weight in any case. To do front tires on narrow front tractor I always drove one tire up on a block of some type regardless of the size of tractor. Normally one short 2"X 4" with another on top a few inches ahead to have a slight ramp.
Dick L
05-09-2019 18:03:39
I have always to jack up both my B's and C's with the woods mower on.
Dick L
05-10-2019 03:39:25
 Re: Changing the front tires in reply to Dick L, 05-09-2019 18:03:39
It better be thick enough or the tractor would break in half at that point. The jack stand was under the lobe under the ell housing.
Redhawk
05-09-2019 18:15:27
Is that jack stand right behind the oil pan? I wasnít sure how thick the housing was there.
old
05-09-2019 16:57:16
A 6X6 or 4X4 under one front tire by using a com-a-long and a tree or a truck as the anchor. Pull it up so one tire is off the ground change it then do it again for the other side
Redhawk
05-09-2019 18:18:39
 Re: Changing the front tires in reply to old, 05-09-2019 16:57:16
Thanks, that sounds like a good option. Are these old tires tube type? I have had this tractor for probably 30 years and this is the first time iíve had a problem with the tires. Guess you canít complain about that!
old
05-09-2019 18:40:01
 Re: Changing the front tires in reply to Redhawk, 05-09-2019 18:18:39
Yes tire are tube type and so are the rims so new tires means either you use the old tubes of buy new ones
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
