Company Logo Shop Now
Removing front eng cover, Gleaner E enging
docmirror
05-06-2019 20:48:15
OK, I have all the cover bolts off. I have the two bolts off the oil pan, and that pin and nut from the end of the shaft. I removed the governor cover, and took the spring off the Gleaner governor shaft.
I gave it a couple taps on the side, to break free and it's locked tight on there. So, I got a little more aggressive and tried whacking it with a pin shaft up by the dist housing. I took the dist shaft out, and tried knocking it forward from inside on the case.
It's stuck tight! I know I've got all the bolts outQuoting Removed, click Modern View to see
docmirror
05-07-2019 06:47:01
 Re: Removing front eng cover, Gleaner E enging in reply to docmirror, 05-06-2019 20:48:15
Yes sir, I've got all those. The dist housing is out, and one stud sticks through the block over there. I don't see any rust around the stud, in fact it's got a fair amount of oil around it.
Aaron SEIA
05-07-2019 04:44:07
I hope you plan on doing pan gaskets when you are done. I had to pull my front cover out a half inch or so and it now leaks like a sieve. Add another project to my list.
AaronSEIA
DrAllis
05-07-2019 04:37:06
Two lower 1/2" bolts for the motor mount. Three 3/8" bolts from the governor around and under the water pump. Two of the three governor/distributer bolts/nuts must be removed. That lower governor housing bolt is a stud and may be rusted to the block ??
docmirror
05-06-2019 21:10:23
Oh yeah, I have the two large bolts underneath that mount the engine to the chassis out also.
Today's Featured Article - Bad Vibes - by Curtis Von Fange. One of the strangest ways to communicate with our tractor is to ask it how it feels. "Ask it how it feels," you say? Yup, ask it how it feels. Now, as with the other articles in this series one has to be able to hear what 'ole blue' is trying to say in response. The nice thing about our old iron friends is that they are usually quite consistent in their response, rather unlike some people I know who might change what they say due to the weather or other mitigating circumstances. But since t ... [Read Article]
Latest Ad: John Deere 855 parts manual. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
