Re: Should I buy a WD????
greg
08-14-2000 07:34:03
i have two wd`s here is some things i like and dont like. they do have three points and a live pto. you can hook up a hydrulic for one way out of your draft control. with a tricycle front end they work great for mowing with a bush hog mower in close places the hand clutch is oil bathed so it dosent hurt to slip it. the down falls is is it needs a couple more gears in it the speed is to fast for the engine power it produces and its hard to mow heavy grass with out riding the clutch also i pull a twelve foot tandem disk with it and if you dont have weighted tires it will spin out on you the other down fall is if you put a three point on it you lose your drawbar other wise its a good tractor hope this gives you some help any questions e-mail me im a antique tractor fan
