1970 One-Sixty Fuel Lines
OneSixty
New User
After 50 years it's time to rebuild injector pump. While it's out it makes sense to replace the injector lines. I'm not having any luck finding the lines online any where.
Does anyone know if the lines used on any of the Massey Fergusons would work on the One-Sixty.
It has a Perkins 3.152 serial number of 152FU36604D
Thank you in advance.
You could try an AGCO dealer. Unless they were leaking I wouldn't replace them, they are special heavy wall tubing and there are many older ones still in use in the world. JMHO.
Thank you for the reply, we've tried our local dealers and they can't get them. Part of the issue is, two of the lines have been rubbing so one of the lines is worn down, it's a matter of time before it starts to leak or burst.
I had a line made for my D19D at a local injection pump shop. They used the old one for a pattern. I have built up worn spots on some up by brazing or silver soldering. Flush well with solvent and air after.
Yep, if they're not leaking, don't replace.
For the ones that may have rubbed through, you can silver-solder the worn area;
a little build-up is OK, but don't get carried away.
Make sure the line is clean before AND after silver-soldering.
The inside cannot have any foreign material in it !!
Thank you for the replies. I'm hoping to get the pump back the beginning of next week. The cost to rebuild it was $850 :shock:
I would think the lines from a M-F with a Perkins 3.152 or any of this engines would work. The engine and
fuel system are Perkins, not Allis/Renault.
