Company Logo Shop Now
TractorLinks.com
Engine Help
Julian12
03-19-2019 20:02:58
Need help diagnosing my Buda 4B153 engine. Under acceleration it keeps backfiring. Iíve replace all plugs, wires, cap, rotor, condenser, and points the gap is set to 0.022. I checked the firing order and itís correct. I tidied adjusting the timing on the distributor which seemed to help a little. I also rebuilt the carb with new neddle and seat it came with instructions on how to rebuild it. I set the air mixture screw 2 turns out and the main jet 3 turns out.
Nordic
03-21-2019 15:30:25
 Re: Engine Help in reply to Julian12, 03-19-2019 20:02:58
You can also check that you don't have any broken valve springs.
Traditional Farmer
03-20-2019 04:38:37
I replaced the Autolite distributor with Delco on two different 30's and cured them that was acting about the same as yours.
Julian12
03-20-2019 23:02:07
 Re: Engine Help in reply to Traditional Farmer, 03-20-2019 04:38:37
my engine already has the Delco distributor
Aaron SEIA
03-20-2019 04:25:16
Try turning the idle and main screws in a bit. Sounds like it might be running rich.
AaronSEIA
Julian12
03-20-2019 23:04:21
 Re: Engine Help in reply to Aaron SEIA, 03-20-2019 04:25:16
when turn the crew in on the mixture screw it does nothing but when I turn the main jet in it wants to die. I also have a hard time starting when cold I need to use starting fluid for a little then it idles fine with choke closed
farmerjohninpa
03-19-2019 23:35:59
hello,is it back firing out the exhaust or through the carb.
Julian12
03-20-2019 23:01:23
 Re: Engine Help in reply to farmerjohninpa, 03-19-2019 23:35:59
backfire on the exhaust side
ReneS
03-20-2019 05:23:06
Check valve lash.Rene'
Julian12
03-20-2019 23:05:03
 Re: Engine Help in reply to ReneS, 03-20-2019 05:23:06
you know what lash is suppose to be on this when cold?
BushogPapa
03-21-2019 09:30:57
 Re: Engine Help in reply to Julian12, 03-20-2019 23:05:03
Start it up, let it warm up some....then open the throttle ALL the Way (on the Quadrant)..then close the Main fuel screw until it labors and/or backfires, then open it back up 1/2 turn ( approx)..
How much depends on whether you are working it Hard ( more), or light..(less)...and I KNOW what I am talking about...!
These nearly always need copious CHOKE, to keep the fire lit until they warm a little.!
Idle, just find the "best" idle and leave it there...
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
