And.......if the tractor sits outside for months at a time, it will allow the clutch to be disengaged to prevent it from rusting fast to the flywheel/pressure plate.
(quoted from post at 10:35:13 03/19/19) Locks it out for hand starting or setting the belt pulley.
AaronSEIA
would add , starting in cold weather is much easier when hand cranking if the clutch pedal is propped down and it is a lot safer, if you accidently left it in gear you won't get ran over when it starts.
Like Aaron says, it was primarily for belt pulley work. When the pulley is engaged and belted up, it is the only way to stop the driven machine and leave the engine running. And of course for hand cranking while belted up.
Here are the directions for use of the clutch pedal lock during Hand cranking the engine and use with the belt pulley from the WD Operator's Manual.
