Company Logo Shop Now
TractorLinks.com
D17 clutch
Trbark
03-15-2019 09:34:18
D17 shuttle clutch won’t say in the high side with out holding it in stays in the low side all day an help
Jim.ME
03-16-2019 12:54:48
 Re: D17 clutch in reply to Trbark, 03-15-2019 09:34:18
It is for hand crank starting. From the operator's manual:
vvfarms
03-16-2019 10:20:51
What is lever next to clutch pedal for? It locks pedal down.On WD tractor.
DrAllis
03-15-2019 16:19:24
I wrote my response in a hurry. I now think you are referring to the Power Director clutch (Low-N-High) as a Shuttle clutch (Rev-N-Forward). Problem and repair is still the same. Remove the 3/8" stop bolt for the hand lever and see what happens.
DrAllis
03-15-2019 11:10:08
There is a 3/8" stop bolt that the shuttle lever comes up against when in forward. Remove that bolt and see what happens. If it still jumps out of forward, the ramp plate and rollers for forward side are worn out. No amount of shimming will cure that. Changing shims might make it worse.
Aaron SEIA
03-15-2019 10:02:57
Is the lock actually catching the latch? Otherwise, it needs the shims adjusted.
AaronSEIA
504
03-16-2019 12:10:50
 Re: D17 clutch in reply to Aaron SEIA, 03-15-2019 10:02:57
I had one that would jump out of high too,if I help it in high with my foot for a little bit, it would stay in high. It was so wore out I sent it down the road,I am trying to think what was not worn out. I do believe the fan blade was OK.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
