Company Logo Shop Now
TractorLinks.com
D19 Rear Tire Width
napper2.0
03-10-2019 18:41:54
Well overheat issue fixed.
Now I am trying to move rear tires inward a few inches to match my snowblower width. Does anyone know how to break the rim free from the axle? Service manual says to remove three 5/8 cap screws on retaining collar, then insert three 3/4 inch jack screws into holes. I did that and turned with large breaker bar and pipe. I was close to breaking the breaker bar and no movement of the retaining collar at all.
I also want to correct what I would call over toe-out of the front wheels but I am unable to break loose the steering arms where they are adjustable. I have saturated both my problems areas with PB Blaster for several days.
Any suggestions would be welcome, thanks!
DrAllis
03-14-2019 05:05:45
 Re: D19 Rear Tire Width in reply to napper2.0, 03-10-2019 18:41:54
And they are GR 8 !!!!
napper2.0
03-15-2019 19:03:11
 Re: D19 Rear Tire Width in reply to DrAllis, 03-14-2019 05:05:45
At least I had that part right!
napper2.0
03-13-2019 13:56:55
Well that is why regular 3/4 inch bolts won't work! Thanks for the picture.
Skyhighballoon(MO)
03-13-2019 11:55:24
Borrowed photo from a post on another site. HTH.
DrAllis
03-12-2019 12:36:38
You must have the factory issued pusher bolts !!!!! Now, you may have damaged the beginning threads for your 5/8" retaining bolts. Be careful when you thread the 5/8" bolts back into place, they might need a tap to clean up the threads on the wheel center.
napper2.0
03-12-2019 14:16:59
 Re: D19 Rear Tire Width in reply to DrAllis, 03-12-2019 12:36:38
You are right they buggered up the threads a bit. I did clean out with a tap and the 5/8 one started fine. Where would one find the correct pusher bolts. Any idea what the ends look like and how they work?
4wdtom
03-12-2019 06:44:04
I have freed up tie rods by taking them off the tractor and placing them on an anvil and tapping just hard enough to jar the outer part, not hitting hard enough to actually dent it. This may slightly expand the outer tube too.
napper2.0
03-12-2019 14:18:41
 Re: D19 Rear Tire Width in reply to 4wdtom, 03-12-2019 06:44:04
Thanks maybe a little less damage than heating them up...
Fred2
03-11-2019 07:52:36
On the front wheels rod adjustment will probably have to some heat to help break it loose.
napper2.0
03-12-2019 06:20:42
 Re: D19 Rear Tire Width in reply to Fred2, 03-11-2019 07:52:36
Great, was trying to save the paint.
DrAllis
03-11-2019 05:20:22
So, you actually have the SPECIAL JACKSCREWS that came with the tractor when it was new?? They are not just an ordinary 3/4" bolt. The special pusher bolts will have to be very tight and smack the end of the axle with a sledge hammer with the wheel off of the ground......and then hope they break loose.
napper2.0
03-12-2019 06:19:41
 Re: D19 Rear Tire Width in reply to DrAllis, 03-11-2019 05:20:22
No, I do not have the original jackscrews. Just used grade 8, 3/4 inch bolts. Maybe that is why it wasn't working?
old
03-10-2019 21:07:51
Loosen the cap bolts then screw them back in finger tight. Then drive it around a bit. Listen for the area to start to make popping sounds. Once they do then stop and you should be able to move the wheels
napper2.0
03-12-2019 18:39:03
 Re: D19 Rear Tire Width in reply to old, 03-10-2019 21:07:51
Thanks, I think I'll give that a try when the weather here dries up.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
