Company Logo Shop Now
TractorLinks.com
D19 Gasser Overheat
napper2.0
03-07-2019 19:13:33
Well here goes. I have a 1963 D19 gasser. I have removed the head, ground the valves and replaced the head gasket. I removed the radiator had it flushed and pressure tested. I have removed and inspected the water pump. The impeller spins with the pulley. I reinstalled with no leaks. I have replaced the radiator cap with proper 4psi replacement. I have replaced the thermostat with a 160F. I have replaced the temperature gauge and sender. There are no leaks in the cooling system.
The engine will run for several minutes then start to overheat, peg the temperature gauge to hot, and boil over. So I removed the thermostat and ran it without it. The engine ran fine for 30 mins without overheating but the temperature gauge never moved from the cold side. So I figured I had another bad thermostat and replaced it with a new 160F. Same story as before run for several mins, temp gauge peg to hot, and radiator boil over.
Any ideas on what could be wrong? I am running out of ideas.
DrAllis
03-09-2019 14:00:13
 Re: D19 Gasser Overheat in reply to napper2.0, 03-07-2019 19:13:33
That engine is a high compression engine and needs to be timed using a timing light. Set the hand throttle at WIDE OPEN and adjust timing to 25 degrees BTDC. Once this is achieved, idle the engine down and the timing should be near TDC with engine at 400 RPM. This will verify whether the centrifugal advance mechanism is working (or not). Anyone who thinks they can correctly adjust the ignition timing on one of these engines without a timing light is fooling themselves. This engine will actually detonate like a car if the timing is too advanced.
neverfear
03-09-2019 04:32:28
Looking at your first post on this tractor,you said you bought it with suspected head and or gasket problems? Did you have the head checked for cracks? How do the water jackets look, full of rust or sediment? What happens when you run without the cap on and watch for flow in the radiator? Have you verified the timing is correct?
Tens of thousands of these tractors worked day in day out with what the factory provided. Something is not right with it.
napper2.0
03-09-2019 06:46:36
 Re: D19 Gasser Overheat in reply to neverfear, 03-09-2019 04:32:28
The inside of the water jacket was a little crusty when I had the head off. I blew it out with compressed air and verified flow through all the openings. I am going to warm it up today drain all the water and give it a vinegar soaking just to clean it up some more. I've had everything checked out that you suggest other than the timing. I drilled a couple of holes in the thermostat and ran it outside for 30 mins from idle to full throttle. The temperature gauge never went above about 140. So it looks to me to be a success.
It seems to run well, arts right up, idles go to full throttle, and shuts of by turning the key with no die selling or backfires. Any easy way to check the timing? I don't have a timing light.
neverfear
03-09-2019 07:04:09
 Re: D19 Gasser Overheat in reply to napper2.0, 03-09-2019 06:46:36
If you haven't had the distributor out it is likely ok. But, you should verify the advance weights move freely. If you don't have a light borrow one from a buddy or auto parts store that loans tools. Since I've been in your position with no timing light before, I've gotten by just advancing the distributor with engine at idle until the engine just starts to labor a bit. Then check by restarting the engine and if it doesn't buck against the starter it's pretty close. Again,this is just to get you by. But to rule timing out as a cause of your overheating you really need to time it by light.
napper2.0
03-09-2019 10:31:36
 Re: D19 Gasser Overheat in reply to neverfear, 03-09-2019 07:04:09
Okay sounds good thanks for the tips. The distributor has not been removed or moved since I've had it.
napper2.0
03-09-2019 06:36:26
The inside of the water jacket was a little crusty when I had the head off. I blew it out with compressed air and verified flow through all the opening. I am going to warm it up today drain all the water and give it a vinegar soaking just to clean it up some more. I've had everything checked out that you suggest other than the timing. I drilled a couple of holes in the thermostat and ran it outside for 30 mins from idle to full throttle. The temperature gauge never went above about 140. So it looks to me to be a success.
Jim.ME
03-08-2019 16:27:13
Drill a hole so it will vent and let coolant pass by and warm the thermostat quicker. Are the valve openings in your replacement thermostats as large as the original? Small openings will slow the flow.
napper2.0
03-08-2019 17:26:09
 Re: D19 Gasser Overheat in reply to Jim.ME, 03-08-2019 16:27:13
I will give that a try. As far as the opening size on the original thermostat, that is unknown since there was not one in there when I bought it. I cross referenced numbers for the original thermostat part number and matched to a current Napa variety.
Jim.ME
03-08-2019 04:03:13
Does the thermostat have a bleed hole in the valve to let the air out when filling as well as pass some coolant which will warm and open the thermostat quicker?
napper2.0
03-08-2019 09:06:01
 Re: D19 Gasser Overheat in reply to Jim.ME, 03-08-2019 04:03:13
No bleed hole that I can see. Someone else suggested drilling a 1/16 hole in thermostat flange to let trapped air through when it is closed. What are your thoughts on that idea?
Traditional Farmer
03-08-2019 04:02:13
Does it have a bypass on it? That could be the problem.The D19 I run now with a Gleaner 262 Combine engine in it was a chronic over heater when worked pretty hard,tried everything I could think of.Finally what worked for me was to take out the thermostat.plug the bypass on the water pump and added a 3 gallon tank that runs the lower radiator hose to the tank and then from the tank to the water pump.Doesn't run hot anymore and works for me as I don't use the tractor much just use it to load hay bales and put a ripper on to tear up deer plots.
napper2.0
03-08-2019 09:03:48
 Re: D19 Gasser Overheat in reply to Traditional Farmer, 03-08-2019 04:02:13
Thank you for your response. It does have a bypass from the waterpump to the bottom of thermostat housing. What did you use for your 3 gallon tank, where did you put it, and how did you route the hoses. I can only guess you didn't use 2 inch radiator house for the plumbing? Thanks again for all your information!
Traditional Farmer
03-08-2019 15:12:09
 Re: D19 Gasser Overheat in reply to napper2.0, 03-08-2019 09:03:48
Used a new hydraulic oil tank I bought at an auction mounted on the left front side up near the radiator,ran flex hoses to hook it all up.Pretty jack leg but it works and since I
don't use the tractor much didn't want to get into some major work on it.The D19 always did run warm if pulled hard think they needed a little more cooling capacity.
Fred2
03-07-2019 19:51:19
Are you sure the thermostat is installed properly
napper2.0
03-07-2019 20:22:52
 Re: D19 Gasser Overheat in reply to Fred2, 03-07-2019 19:51:19
Yes I believe so. Copper core with spring toward engine.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
