D17 Gas 4 Cyl. Hotter Spark Plugs.
eye4iron
What is a good recommended hotter spark plug for a D17 gas 4 cyl..? I have one plug that will oil foul about once a year. I believe I can pull the valve cover at a latter date and install some valve guide seals to limit the oil fouling.
But until then I would like to run a hotter plug. Any suggestions or advice.
AC Delco R46 or R47 for the 3/8" length and AC Delco R46XL or R46XLS or R47XL or R47XLS for the 3/4" length.
Thanks for the replies.
They are the 3/4? reach.
Dr. Allis. Are those plug numbers stock or a hotter range.
Don't know About the "stock" number, but have learned that the smaller the number, the hotter the plug.
(quoted from post at 17:08:07 02/11/19) Don't know About the "stock" number, but have learned that the smaller the number, the hotter the plug.
Well, that isn't the case with AC Delco plugs. 45XL is stock. 46-47-48's are all HOTTER.
