Michaelr0953
New User
Hi folks, I have a 1941 Allis chambers b. I have a problem with it losing spark, I would remove just the distributor cap wipe it off and it would start right back up. After a few times of that, I removed the rotor body checked the points and condenser. ( of course I can't find no marks on fiber gear) it be nice if I could find picture of a new fiber gear I would just count the teeth)). So I went through standard procedure making sure number one cylinder was coming up to top dead center via thumb in the spark plug hole, checking the fly wheel line center mark . Then lined the rotor button up on the timing boss Mark in the rotor body. I advanced the engine around and observed the rotor at each magneto snap ended at the next cylinder according to the distributor cap. I replace the rotor body put a Phillips screwdriver in the hole touch the coil and rotated the engine and he had spark at the coil. I clean the contact rod that goes through the rotor body to the coil . And replaced the distributor cap. My problem is I'm losing spark between the rotor button and the spark plug and I don't know why? The rotor button looks new but distributor cap is not, but the contacts do not look worn.
