Company Logo Shop Now
Allis charmers 7040 hydraulic fluid pumping into the rearend
Ssrfarms
01-10-2019 17:47:56
I have a Allis Chalmers 7040 that is pumping hydraulic fluid from the transition into the rear end. Is this due to a bad seal in the stack of pumps ? Any help would be appreciated!
DrAllis
01-11-2019 05:26:42
 Re: Allis charmers 7040 hydraulic fluid pumping into the rea in reply to Ssrfarms, 01-10-2019 17:47:56
That is usually what it is....the shaft seal between the gerotor (transmission) pump and the steering (rear end) pump. Now, that being said, there could be serious pump bushing/bearing issues causing the seal to leak. It's been 25 years since I've replaced one of those seals and those tractors are now 25 yrs older.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want unless you own a monster tractor. U ... [Read Article]
Latest Ad: Oliver model 101 1-16 rope trip plow on steel. Includes new share/point and great mouldboard. 300 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
