Company Logo Shop Now
TractorLinks.com
WC vs WD for mounted corn picker
vj
01-09-2019 17:31:33
I have a 2 row tractor mounted AC corn picker that doesnít seem to have a model number. I have the operators manual and it doesnít give a model number either. The manual shows mounting instructions for both styled and unstyled WC tractors. My question is, would this picker fit on a WD?
JMS/.MN
01-10-2019 19:08:52
 Re: WC vs WD for mounted corn picker in reply to vj, 01-09-2019 17:31:33
Their was an early mounted picker that did not have a model number. That was not unusual. The model 33 came out later. In October 1951 Dad bought a WC with the early picker. I was 7 yo and the dealer drove it to our farm...he said I should tell Dad that the tractor hadno antifreeze in it.It had a lever on the right side (rear) that was used to adjust the picker height. The early picker should fit a WD. The fan assembly should fit under the gas tank and forward of the battery. It is driven by the belt pulley. The tractor pto is removed and the short shaft on the picker connects to the stub shaft of the pto gearbox.
vj
01-11-2019 13:35:55
 Re: WC vs WD for mounted corn picker in reply to JMS/.MN, 01-10-2019 19:08:52
From what youíve stated I would say I have the early unnumbered picker. Pictures in the book show the belt pulley drive and the hitch and pto shaft removal. The reason I question the mounting is that the tractor rear end housings are somewhat different and that makes me wonder if it will fit on the WD which would be my preference. Perhaps the picker (and manual) were made prior to the WD being made. That would answer why it isnít shown in the manual but still leaves the question as to whether if will fit the WD. Thank you all for you help!!
JMS/.MN
01-12-2019 19:44:17
 Re: WC vs WD for mounted corn picker in reply to vj, 01-11-2019 13:35:55
I can"t quite remember the brackets on the finals that held the rear of the picker, but the brackets that hold the elevator up would have to be different as well. The WC brackets attached to the tapped holes on top of the rear axle. Those holes are not on a WD final.
tomstractorsandtoys
01-10-2019 06:06:20
If at all possible put it on the WD. You would have live pto which you will be glad for. You need to post on the Allis Chalmers Forum as there is lots more info there than here on pickers. Grandfather had a new styled WC with a two row picker. Tom
Traditional Farmer
01-10-2019 03:33:54
Probably a Number 33 picker,mounts would be different for a WD,they were quite a rig.
old
01-09-2019 19:24:35
WC and WD used the same engine but different transmissions and the WD had hyds where as the WC does not. I would think it would fit on both and the plus would be the hyds could be set up to do the lifting of the heads
d beatty
01-09-2019 22:24:09
 Re: WC vs WD for mounted corn picker in reply to old, 01-09-2019 19:24:35
You also have the hand clutch which come in handy in downed corn . You can stop the movement of tractor while picker can keep running.
