Will an Allis Chalmers G fit in a pickup?
sodly
Has anyone ever tried to carry an Allis G in the bed of a full-size pickup? Will it fit? Any pics? Thanks!
I presume a B or C Allis is longer than a G, correct? Or would either of those fit in an 8' box, by chance?
A G will fit with the tailgate down, I'd back it in as there's lots less weight on the front tires and that will put much less strain on the tailgate support links
tight fit without an engine with wheels turned 90 degrees!
<a href="https://s33.photobucket.com/user/Joecdeere/media/DSC00294.jpg.html" target="_blank">
</a>
Wife's uncle hauled his AC B in a 1979 Chevrolet 3/4 ton on several occasions. Said it worked great.
I did. T took the gate off and pulled straight in with wood ramps on the step bumper. Didn't want to put the rear weight on the tailgate. The nose was higher that the bed so I put large wood blocks in front of the front tires to keep it from going through the rear window.
A G is a pretty small tractor so yes likely to be able to. I once knew a guy who had a Ford N series don't remember which one but he would haul it in his 3/4 ton pickup all he needed was some place to back into a ditch so he could then drive it out of the bed of his truck
Are there any other vintage small tractors that can fit into a 3/4 ton pickup box? Maybe an Allis IB? Any photos are appreciated.
There are probably a good number of them. Like the Ford N series or the A/C B. Shoot I have a Celtrac HG42 that will almost fit in a pickup
