allis chalmers 5020 front end loader
jrbohannon
New User
I have a 1980 allis chalmers 5020. I just purchased a brantly front end loader from a sotoh654g. I need a mounting bracket to fit the loader to my tractor. I also need directions on how to hook up the hydraulics. I am new to tractor ownership and any help will be appreciated.
38 year old tractor and you are hunting a loader bracket.. Ever heard of the guy hunting for the needle in a hay stack. I think that guy would have better luck than you are going to have. Cutting torch and welder with some scrap iron will be you only choice, at least that is my bet.
You just found that needle I have a parts AC 5020 with the loader mounts/frame on it.What part of the country are you located? I'm in Virginia.I have no idea how the hydraulics were
hooked up.
I am located outside Houston, tx. I would like to discuss with you about buying but mostly how do we ship it? Do you know about how much they weigh and also I would like all the mounting bolts. Could you send me some pictures. My cell # is 281-389-3014
I'll go up and look things over and give you a call later.Do you need the whole frame or just the mounts? BTW I have a sister that lives North of Houston in Montgomery County,are you anywhere near there?
Yes I live in southwest Montgomery county outside a small town called magnolia. I am headed off to work but you can call or text anytime. I have the complete loader except the brackets that come off the sides and the uprights that the loader arms bolt to.
I can not believe it, I would have bet he would be looking forever.. Story is not over he wants the bolts,, and yes will want you to deliver it to Houston.. LOL.. But you could contract me to carry it down because I want to come up and meet you anyway.. LOL
hello, just got in from work and was wondering if you had a chance to take some pics. if you did I would appreciate it if you could text them to me. if we can get together on this I will try to figure out how to get it here
Keep in mind that tractor does not have power steering, and I
don?t see how it could be added because of its design.
You can use the power steering from a Gleaner combine. You have to cut the steering ling on one side and fab in the director valve and cylinder mounts to the tie rod.
(quoted from post at 13:45:09 01/12/19) You can use the power steering from a Gleaner combine. You have to cut the steering ling on one side and fab in the director valve and cylinder mounts to the tie rod.
k thanks i will see if i can do that. not the best fabricator in the world
Hello, I know you are probably snowed in but I just wanted you to know I still want those brackets when you get a chance. just call me and we can make arrangements to have them shipped.
