Re: Need head gasket advice.
Tony H
12-01-1998 19:13:22
You will need to replace the freeze plugs in the head. I would bet this is where the coolant is getting into your oil. You may have bad O-Rings on the bottom of the sleaves and this will require a overhaul. I would pull the head and if I did not find the problem here I would do a complete teardown. Gaskets are expensive to replace twice.
