1954Frank
What rear tires are you folks running on your "C" tractors? Tractordata.com has 9-24. I looked online and cannot find any new 9-24's. I found 8.3 and 9.5, and larger.
Most of my B's and C's have 11-2-24's My C I pulled with I had 12-4-24's. I do have a crank start I used to cultivate with 9-5-24's I had planed on putting 13-6-24's on one C but never bought them.
9-24 is the "old" tire designation. 9.5-24 is the new designation. I run 11.2-24's (10-24) on my B. It really depends on if you have 9" or 10" rims.
<a href="http://www.millertire.com/faqs/">Miller Tire Size Chart</a>
With only a 3 speed transmission I'd stick with the smaller tires if I was going to do work with the tractor the 1st gear is too fast for a lot of things anyway.If you're just going to drive
it around and look at it doesn't matter what you put on it.
FYI. I just checked with my old tire suppliers, if you are going to purchase new tires they are out there. If I still had my tire shop, They 11.2X24 should cost you less than 200.00 each put on the rims at the tire shop provided the rims were still on the tractor.
A Firestone 11.2 is 141" circumference, a 12.4 is 146". The width of the 12.4 looks better in my opinion.
AaronSEIA
