Company Logo Shop Now
TractorLinks.com
C Tires
1954Frank
11-07-2018 13:09:19
What rear tires are you folks running on your "C" tractors? Tractordata.com has 9-24. I looked online and cannot find any new 9-24's. I found 8.3 and 9.5, and larger.
Aaron SEIA
11-08-2018 18:08:19
 Re: C Tires in reply to 1954Frank, 11-07-2018 13:09:19
9" and 10" were available for a C.
AaronSEIA
Aaron SEIA
11-08-2018 16:43:02
A Firestone 11.2 is 141" circumference, a 12.4 is 146". The width of the 12.4 looks better in my opinion.
AaronSEIA
Hd6gtom
11-08-2018 13:26:09
FYI. I just checked with my old tire suppliers, if you are going to purchase new tires they are out there. If I still had my tire shop, They 11.2X24 should cost you less than 200.00 each put on the rims at the tire shop provided the rims were still on the tractor.
Traditional Farmer
11-08-2018 00:02:22
With only a 3 speed transmission I'd stick with the smaller tires if I was going to do work with the tractor the 1st gear is too fast for a lot of things anyway.If you're just going to drive
it around and look at it doesn't matter what you put on it.
Aaron SEIA
11-07-2018 16:58:47
I wouldn't run anything smaller than an 11.2. A 12.4 would look a little "meaner".
AaronSEIA
bjb in Tx from Ne
11-07-2018 13:47:57
9-24 is the "old" tire designation. 9.5-24 is the new designation. I run 11.2-24's (10-24) on my B. It really depends on if you have 9" or 10" rims.
Miller Tire Size Chart
1954Frank
11-08-2018 18:03:56
 Re: C Tires in reply to bjb in Tx from Ne, 11-07-2018 13:47:57
What was the stock/ standard rim width on a C? Or did it vary over time? Were there options?
Thanks
Dick L
11-07-2018 13:19:48
Most of my B's and C's have 11-2-24's My C I pulled with I had 12-4-24's. I do have a crank start I used to cultivate with 9-5-24's I had planed on putting 13-6-24's on one C but never bought them.
