Question if you don't mind. Finally got a gauge to check the hi/lo valve on the 200. Can't get much over 180 on high and a little less on low. Am I looking at a pump issue?
Clamp a vise grips on that cross shaft that moves the Power Director valve spool and force the spool out and in farther. Those tractors are known for linkage issues that don't stroke the valve spool 100%. With a fully stroked spool, you should be around 300 psi or a little more. Not a pump issue, but the pressure control valve on the Power Director valve needs to be shimmed up higher or there is an internal leak causing low pressure.
DO NOT SHIM ANYTHING UNTIL YOU KNOW THAT YOUR SPOOL IS FULLY STROKED TO GET AN ACCURATE PRESSURE READING !!!
