6 cyl 11000 turbocharged engine
55 50 Ron
What is the coolant capacity of this engine?
Other specs I have for it list it at 516 cu in and 210 HP at 2200 RPM. It's in a Shafer model 20,000 4WD tractor that we have at Farmamerica.
Thanks, Ron
I searched around and found a site that mentioned 44 quarts. Seems a bit high but that's a big engine.
Cooling system capacity depends on the size of the engine coolant passages and the size of the RADIATOR. Fill it until it is nearly full. A 7060/7080 hold 8 gallons, so I'd guess that 516 engine would be more than that.
