Need to remove the 18.4x34 eight ply tire mounted on an 190XT. The tire is very old and stiff and I think it may be the original tire. The bead is broken on both sides. Now I need to remove the tire from the rim.
I have put blocks of wood all around the inside and the front half of the tire to move the bead off the flat part of the rim. I have lowered the tractor so there is pressure on the bottom to push the tire up into the drop part of the rim on the bottom. I have been able to get about an eight inch section of the front bead past the outside of the rim at the top. It is really getting tough at this point to get more of the tire off. I would appreciate any help on how I should proceed. Also are there any lubricants that I should be using ? Would also like to hear any experiences you have had.
Thank you in advance for any help you can give me.
